Ozzie Posted June 21, 2014 Share Posted June 21, 2014 In a top plan view if I use the Move By Points Tool and whilst it is still active use keyboard short cut Alt = to use the Rotate Tool the Move By Points Tool does not disengage allowing the Rotate Tool to become Active If doing the same and I use keyboard shortcut say 1 for Text, Text does become active If I have selected an object and use the Rotate Tool ? Alt = and then use Ctrl M to activate the Move By Points tool it deactivates the Rotate Tool Therefore shouldn?t the Rotate Tool shortcut deactivate the Move by Points Tool as the opposite works? Or am I nuts or is it Windowz or is there another reason? Quote Link to comment
Bob Holtzmann Posted June 21, 2014 Share Posted June 21, 2014 I always use the X key to disengage an active tool, to get back to Selection mode. The Escape key does the same thing in other CAD apps, but it looks like Vectorworks doesn't use it. Quote Link to comment
Ozzie Posted June 21, 2014 Author Share Posted June 21, 2014 I do too Bob but how come the Move By Points Tool it seems does not disengage? Quote Link to comment
Bob Holtzmann Posted June 21, 2014 Share Posted June 21, 2014 It works for me in MacOSX, even when using the Rotate tool, it can switch to the Move By Points tool, and then back to Selection - you're saying pressing the X key does not work? How about the other tools, like 2D Poly and Walls? Quote Link to comment
Ozzie Posted June 22, 2014 Author Share Posted June 22, 2014 If I draw a rectangle select it Shift+M move the rectangle then say 9 I can draw a wall straight away but doing same thing .... draw a rectangle select it Shift+M move the rectangle then say Alt+= the little round protractor thingy is there for a moment but disappears straight away and the Rotate Tool does not engage If I select the Tool directly from the Basic Tool Palette it does Quote Link to comment
JoshW Posted June 23, 2014 Share Posted June 23, 2014 The Alt key in the move by points tool allows you to select a different object and then snap back to move by points. It's one of those quirky Vectorworks things. I'm not sure if it is an actual bug or what (Maybe JimW can shed some light on that area). One way to solve this would be to change the short cut for the rotate command to something that doesn't involve the alt key. Quote Link to comment
Ozzie Posted June 23, 2014 Author Share Posted June 23, 2014 Thanks Josh but wouldn't you think releasing a tool by selecting another should be consistent I thought maybe a Windowz or W8.1 thing Quote Link to comment
Vectorworks, Inc Employee PVA - Admin Posted June 23, 2014 Vectorworks, Inc Employee Share Posted June 23, 2014 I see it now. This is happening because this tool takes input from the Alt key directly, so it is not possible to use an Alt+(anything) shortcut while the Move by Points tool is active. You could simply click the tool in the basic palette, but a keyboard shortcut that includes Alt as its first key press wont let you change to another tool. I don't see a way of resolving it though, other than by changing the keyboard shortcut to one that does not include the use of the Alt key. I will submit it however just in case. Quote Link to comment
Ozzie Posted June 23, 2014 Author Share Posted June 23, 2014 Is a tool already assigned Shift = as a Shortcut? Quote Link to comment
Bob Holtzmann Posted June 23, 2014 Share Posted June 23, 2014 I use the M key (no modifiers) as the Move Tool, because it's easy to type, and also because it's easier to remember with Command-M as the Move Command. Similarly, I use the J key for the Connect / Combine Tool, because its function is similar to Command-J, the Join Command. Quote Link to comment
