JoshW Posted June 20, 2014 Share Posted June 20, 2014 Is it possible to set the default slab style for create objects from shapes or does vectorworks just pull the first one in the resource browser? Should this be a wish list item? Quote Link to comment
Vectorworks, Inc Employee PVA - Admin Posted June 20, 2014 Vectorworks, Inc Employee Share Posted June 20, 2014 Looks to me like it ALWAYS creates an unstyled slab, not even picking one of the styles at all. There doesn't appear to be any way to do it in one step either, as for converting geometry to Slab objects, you aren't offered the choice to "Show Properties Dialogue" as with some other objects. The user always has to convert geometry to slab, then manually change the slab style after via the OIP. A wishlist item indeed, submitting it now. Quote Link to comment
JoshW Posted June 20, 2014 Author Share Posted June 20, 2014 I have some custom slabs styles that I have created in my file. So it seems as though it is just pulling the first one from the list. Quote Link to comment
Vectorworks, Inc Employee PVA - Admin Posted June 20, 2014 Vectorworks, Inc Employee Share Posted June 20, 2014 I'll add that to the case, needs to be user controllable. Quote Link to comment
Guest Wes Gardner Posted June 20, 2014 Share Posted June 20, 2014 Another method is to store your custom slab styles as Favorites, then once you've run the "Objects from Shapes" command to create the Unstyled slab, just double click on one of the styles in your Favorites and voila! Quote Link to comment
JoshW Posted June 20, 2014 Author Share Posted June 20, 2014 I should still be able to just create the slab style I want from step one though. Quote Link to comment
