jgmrussell Posted May 26, 2014 Share Posted May 26, 2014 Hi, I'm drawing a room with 2 walls of different heights. I drew all 4 walls of same height and I'm trying to figure out how to adjust the walls to make the angled side walls, any ideas? I did a search but could not find anything, thank you. John Quote Link to comment
michaelk Posted May 26, 2014 Share Posted May 26, 2014 2 ways: Go to a 3D view. Double click on a wall. A wall version of the reshape tool becomes active. Blue handles will appear on the wall. You can move, add, and subtract vertices like with 2D shapes. Create a 3D shape of the "ceiling". Move it to a new layer. Select the walls. AEC > Fit Walls to Objects? > check 'Constrain Tops of Selected Walls to Objects' and choose the layer with the geometry that you just created. hth mk Quote Link to comment
jgmrussell Posted May 27, 2014 Author Share Posted May 27, 2014 Hi Michael, I figured out after I posted about reshape tool. Thank you for your suggestuions, very helpful. John Quote Link to comment
JesusDelmonte Posted November 28, 2022 Share Posted November 28, 2022 Hi i cant manage to edit the wall as OP described using the reshape tool in 3D. Im using Vectorworks 2023 has changed this process but i cant figure it out. There is no 3D Reshape tool anymore and the 2D Reshape tool does not work for this in 3d view. Quote Link to comment
Tom W. Posted November 28, 2022 Share Posted November 28, 2022 There is now the dedicated Edit Wall Tool 3 Quote Link to comment
