PIO Button in OIP
  • 10 months later...
... still trying to store data in record-fields ...
The data actually passes to record fields but are being reset when re-entering the dialogue via the "Button 1"-dialogue. Am I missing a loop somewhere?
PROCEDURE Point_Object;
CONST
Confirm					= 01;
Cancel					= 02;
Reset_PIO				= 03;
k_Icon					= 05;
PIO_Controls_Palette	= 08;
k_Palette_Button		= 35;
VAR
PIO_N				: STRING;
PIO_H, PIO_R, PIO_W	: HANDLE;
Event, Result		: LONGINT;
Bool				: BOOLEAN;
Dial_ID, Dial_Res	: INTEGER;
D_X, D_Y, D_Z		: REAL;
PROCEDURE Result_A;
BEGIN
	IF GetCustomObjectInfo (PIO_N, PIO_H, PIO_R, PIO_W) THEN
	BEGIN
		Rect (0, 0, pD_A, pD_B);
		Message (GetRField (PIO_H, 'Rec_N', 'Data X'));
	END;
END;
PROCEDURE Result_B;
BEGIN
END;
PROCEDURE Records;
BEGIN
	NewField ('Rec_N', 'Data X', Concat (D_X), 9, 0);
	NewField ('Rec_N', 'Data Y', Concat (D_Y), 9, 0);
	NewField ('Rec_N', 'Data Z', Concat (D_Z), 9, 0);
END;
PROCEDURE Dialogue_A;
	PROCEDURE Layout_Dialogue_A;
	BEGIN
		Dial_ID		:= CreateResizableLayout ('Dialogue A', TRUE, 'Confirm', 'Cancel', TRUE, TRUE);
			CreateCheckBox		(Dial_ID, 100, 'Do Something');
			CreateStaticText	(Dial_ID, 110, 'Data X:', 20);
			CreateEditReal		(Dial_ID, 111, 3, D_X, 20);
			CreateStaticText	(Dial_ID, 120, 'Data Y:', 20);
			CreateEditReal		(Dial_ID, 121, 3, D_Y, 20);
			CreateStaticText	(Dial_ID, 130, 'Data Z:', 20);
			CreateEditReal		(Dial_ID, 131, 3, D_Z, 20);
			SetFirstLayoutItem	(Dial_ID, 100);
			SetBelowItem		(Dial_ID, 100, 110, 0, 0);
			SetRightItem		(Dial_ID, 110, 111, 0, 0);
			SetBelowItem		(Dial_ID, 110, 120, 0, 0);
			SetRightItem		(Dial_ID, 120, 121, 0, 0);
			SetBelowItem		(Dial_ID, 120, 130, 0, 0);
			SetRightItem		(Dial_ID, 130, 131, 0, 0);
	END;
	PROCEDURE Dialogue_A_Handler (VAR Item, Data: LONGINT);
		PROCEDURE Dialogue_A_Settings;
		BEGIN
			Bool	:= GetEditReal (Dial_ID, 111, 3, D_X);
			Bool	:= GetEditReal (Dial_ID, 121, 3, D_Y);
			Bool	:= GetEditReal (Dial_ID, 131, 3, D_Z);
		END;
		PROCEDURE Confirm_Handler;
		BEGIN
			BEGIN
				AlrtDialog (Concat (D_X));
				SetRField (PIO_H, 'Rec_N', 'Data X'	, Concat (D_X));
				SetRField (PIO_H, 'Rec_N', 'Data Y'	, Concat (D_Y));
				SetRField (PIO_H, 'Rec_N', 'Data Z'	, Concat (D_Z));
			END;
		END;
		PROCEDURE Cancel_Handler;
		BEGIN
		END;
	BEGIN
		CASE Item of SetUpDialogC: Dialogue_A_Settings;
			01	: Confirm_Handler;
			02	: Cancel_Handler;
		END;
	END;
BEGIN
	Layout_Dialogue_A;
	IF VerifyLayout (Dial_ID) THEN Dial_Res := RunLayoutDialog (Dial_ID, Dialogue_A_Handler);
END;
PROCEDURE Dialogue_B;
BEGIN
	AlrtDialog ('Here''s nothing going on');
END;
BEGIN
vsoGetEventInfo (Event, Result);
CASE Event OF
	k_Icon:
	BEGIN
		Bool	:= SetObjPropVS (PIO_Controls_Palette, TRUE);
		Bool	:= vsoInsertAllParams;
		Bool	:= vsoAppendWidget (12, 100, 'Button 1', 0);
		Bool	:= vsoAppendWidget (12, 200, 'Button 2', 0);
	END;
	k_Palette_Button:
	CASE Result OF
		100:	Dialogue_A;
		200:	Dialogue_B;
	END;
	Reset_PIO:
	BEGIN
		PushAttrs;
			Result_A;
			Result_B;
			Records;
			Record (PIO_H, 'Rec_N');
		PopAttrs;
	END;
END;
END;
RUN (Point_Object);
