JulieK Posted May 9, 2014 Share Posted May 9, 2014 I have several rectangles on my floor plan which represent stone columns. I gave them a solid fill so that they would look solid on the floor plan, but when I extrude them, they lose their fill. If I edit the extrude, the original object still has its fill, but it disappears again when I exit the editing mode. Quote Link to comment
michaelk Posted May 9, 2014 Share Posted May 9, 2014 Yes. 3D solids appear in wireframe in Top/Plan. You can either: 1. use Create Auto Hybrid. Depending on your column, you may need to change the Cut Plane Elevation 2. Run the Pillar? command on your rectangle. This will give it a 2D representation as well as 3D. 3. Create a hybrid symbol. hth MK Quote Link to comment
easyray Posted May 10, 2014 Share Posted May 10, 2014 yeah, this is an annoyance that i encounter frequently and am dealing with right now (but never get around to listing it as a wish). but, i do wish that 3d solids appeared solid in top/plan, using the same fill and line as their class. i get tired of taken extra steps as michael is describing. in the mean time i find the auto hybrid best, but sometimes make floors, or sometime simply draw a rectangle over the extrude. but, i wish i didn't have to do this. thanks, julie, for reminding me to come on here and say that. ray Quote Link to comment
