I would like to see the drawing label numbering made smarter so that it sees drawing labels that are directly on the sheet layer (ie. instead of being associated with a sheet layer viewport specifically). I often place reference photos on sheets and use the drawing label to label them in sequence with other drawing elements. The automatic numbering gets confused by this. I know I could put them on a design layer and use a sheet layer viewport as a workaround but I would like the flexibility to be added. The automatic numbering also gets confused if you put a sheet layer viewport in a group. It would be great to sort these issues out.
Kevin McAllister
Thanks,
Kevin
3 answers to this question
