tpenna Posted May 2, 2014 Share Posted May 2, 2014 Is there a way to change the size of the circle, hexagon, etc. containers in VW2012? I couldn't find the answer in F1. Quote Link to comment
Vectorworks, Inc Employee klinzey Posted May 2, 2014 Vectorworks, Inc Employee Share Posted May 2, 2014 You can change the container size by editing the symbols in the container folder in the resource browser. You can also add your own symbol containers to this folder and they will be available in the Label Legend manager. Quote Link to comment
tpenna Posted May 3, 2014 Author Share Posted May 3, 2014 I don't see a container folder in the resource browser. Under Record Formats there are files titled Light Info Record, Light Info Record M, and Parts. Under Symbol Folders there are only symbols; nothing about containers. Keep in mind I'm using VW2012, in case that makes a difference. Quote Link to comment
SAR Posted May 4, 2014 Share Posted May 4, 2014 You might want to look at another light plot and see if you have a symbol folder is in that drawing. If so, them import the folder to and then edit your symbols. The folder called containers should be there under the symbol folders section of the resource browser as Kevin mentioned. You can also create a folder called containers and make your symbols. The label legends will use this folder for your containers. Steve Ross Quote Link to comment
