Bruce Kieffer 158 Posted April 29, 2014 Please remind me how do I change a viewport view from one perspective to another of my saved views? Basically I want to redefine the custom view without having to create a new viewport. Quote Share this post Link to post
PVA - Jim 2,389 Posted April 29, 2014 If you edit the crop of the viewport, then activate that saved view and exit the crop, it should then be the new view for that viewport. You may have to re-position the viewport afterwards however. Quote Share this post Link to post
Bruce Kieffer 158 Posted April 29, 2014 Activating another saved view while in the edit viewport crop mode takes me to the other view on its design layer. Quote Share this post Link to post
ionw 0 Posted April 29, 2014 Bruce, edit the saved view to not set the active layer. Cheers, Ion Quote Share this post Link to post
Bruce Kieffer 158 Posted April 29, 2014 I guess I need more steps. I can't figure it out. I want to change the viewport from one saved view to another saved view. So far the easiest way is to create a new viewport. I know I've used the viewport edit design layer before to do things like this, but I can't remember how. Quote Share this post Link to post
PVA - Jim 2,389 Posted April 29, 2014 (edited) If you go to Tools > Organization > Saved Views, edit the saved view and make sure it is NOT set to change the currently active layer. Next to "Active Layer", make sure it is set to "Don't Save" so that your current active layer within the viewport isn't altered just by selecting another saved view. This is enabled by default when you create a new saved view, but is not always desired or necessary. This covers a few of the specifics with saved views: Edited April 29, 2014 by JimW Quote Share this post Link to post
Bruce Kieffer 158 Posted April 29, 2014 I still don't understand how I get the viewport to change the view from my #1 saved view to my #2 saved view? Jim, you say; "If you edit the crop of the viewport, then activate that saved view and exit the crop, it should then be the new view for that viewport." My problem is activating the other saved view. When I do that Vectorworks exist the viewport and goes to the saved view in the design layer. Quote Share this post Link to post
PVA - Jim 2,389 Posted April 29, 2014 Apologies, I see that now. It looks like the only ways are to create a new viewport if you want to use a saved view, or to manually manipulate the view into position while editing the crop of the existing viewport. Quote Share this post Link to post
Bruce Kieffer 158 Posted April 29, 2014 Yes. I will need to go to the other saved view and create a new viewport. I was coaxing my brain to remember what I had done in the past, and then I remembered I was not trying to change a view, but rather recreate a deleted saved view from a viewport. That can be done by entering the viewport edit design layer and creating a new saved view while in the design layer editing mode. Quote Share this post Link to post
Jim Smith 334 Posted April 30, 2014 Thanks for the link Jim. I was grumpy about the naming hierarchy when Viewports were first introduced, & as some suggested now that I've used it for some time now I would not go back. Having said that, I thought that Saved View was a legacy tool & have not really used it in years other than opening old files. This video helps explain that Saved View can be a helpful tool in working on complex drawings without cluttering up the file with Viewports that don't get printed... .... but I still may do that too! 8-) Quote Share this post Link to post
