fich Posted April 15, 2014 Share Posted April 15, 2014 (edited) Hi I'm a newbie so most likely I have just not found the right tutorial ? In 2D I have foot paths, areas of meadows and other areas of lawn (all closed polygons). How could I drape them on the existing surface of the site model (which is, of course, not flat). They should not modify the site model. fich Edited April 15, 2014 by fich Quote Link to comment
Benson Shaw Posted April 15, 2014 Share Posted April 15, 2014 (edited) Send to Surface in the Landmark menu. The 2d objects need to be polygons or poylines. Rectangles, ovals and other object types need to be converted to polygons. Texture beds are nice, too, but they modify the model. -B Edited April 16, 2014 by Benson Shaw Quote Link to comment
fich Posted April 17, 2014 Author Share Posted April 17, 2014 Thanks Benson, The trick is the 2d polygon, any other object is not doing the drape. They are just moved on the z-axis without changing their appearance according to the site model. In wire frame I can see the drape over the site model (mash solid) Unfortunately non of the render options produce something that looks like a draped object (or a foot path over a hill) Did I miss anything? Quote Link to comment
ray isaacs Posted April 18, 2014 Share Posted April 18, 2014 are the polygons closed? when using the send to surface method, i find i usually have to raise the polygon slightly above ground surface in order to see it properly. the more complicated the terrain, the more i have to raise it. ray Quote Link to comment
Benson Shaw Posted April 18, 2014 Share Posted April 18, 2014 Some 2d polys make a sort of trough when sent to surface, with a ground plane object and two faces extending from the ground up to the dtm. The area between the top edges is not a surface. Another way is to draw the edges of the path as 2 polylines, send to surface (they become 3d polys), Convert to NURBS, and loft between them. Or, if the pathway starts as a closed poly sent to surface, reduce the shape to 2 NURBS curves and loft a new surface between them. Either extract those edges & Convert to NURBS, or cut the "trough" at the corners. As Ray says, it may be necessary to move the new surface upwards a bit to see it in renders. Look up Texture Beds. They eliminate some of the problems of areas which end up slightly under the dtm. hth -B Quote Link to comment
fich Posted April 18, 2014 Author Share Posted April 18, 2014 2d polylines, lofting and then raising worked for me thanks Quote Link to comment
