Archicad
Thom
It is really a problem to work between VW and Archicad. The best you can do is to export a .dxf or .dwg file from each program to bring changes into the other platform, then edit your drawing based on the geometry of the changes. Solids go back and forth as 3D polygons only. Note that the color of a 3D shape will not be the color you selected for the surface when translated into .dxf - it will be the color of the lines.
