JulieK Posted April 5, 2014 Share Posted April 5, 2014 I'd like my door symbols to show as double lines in my reflected ceiling plans, but they are not. My door objects show up fine, but the doors that I've converted to symbols do not, even though I've checked the box that says "draw wall lines". Is there something I'm overlooking? I'm using Vectorworks 2014. My operating system is OSX 10.9.2 Quote Link to comment
Melynda Posted September 25, 2014 Share Posted September 25, 2014 Hi Julie, did you get an answer for your question 'Wall lines of door symbols not showing on reflected ceiling plan''? I have the same problem. Thanks Quote Link to comment
Guest Wes Gardner Posted September 25, 2014 Share Posted September 25, 2014 Try mine... Turn on the class called Ceiling-Main. This controls the wall lines. The door on the left is NOT a symbol, the door on the right IS. Does this work for you? Wes Quote Link to comment
Melynda Posted September 25, 2014 Share Posted September 25, 2014 Hi Wes, Thank you very much for your answer. Unfortunately I am not able to open your file. Vectorworks tells me it is an unrecognized file. That it may have been created by a newer version or it may be a very old MiniCAD file, or created by another application... Quote Link to comment
Guest Wes Gardner Posted September 25, 2014 Share Posted September 25, 2014 Hi Melynda, That file was created in 2015. What version are you using and I'll convert it. Wes Quote Link to comment
RGyori Posted September 26, 2014 Share Posted September 26, 2014 I'd like my door symbols to show as double lines in my reflected ceiling plans, but they are not. My door objects show up fine, but the doors that I've converted to symbols do not, even though I've checked the box that says "draw wall lines". Is there something I'm overlooking? I'm using Vectorworks 2014. My operating system is OSX 10.9.2 Hello Julie, I've come to the conclusion that door symbols will not behave correctly in reflected ceiling plans even with sills class off and ceiling main class on. A door plug-in however does behave as expected. One can convert a door plug-in to a symbol by checking "convert to plug-in object" in the create symbol menu and it will create a symbol (noted in red) in the Resource Browser. This allows you to place doors configured per your specifications repeatedly and they will behave properly in a reflected ceiling plan. The down side is that doors placed this way exist in the plan as pug-in objects NOT as symbols thus potentially bloat the file and cannot be edited from the resource Browser and have change appear in all placed doors. To all viewers please correct me if I am wrong! Quote Link to comment
Melynda Posted October 2, 2014 Share Posted October 2, 2014 Hi Wes, Vectorworks 2013 Thank you very much! Quote Link to comment
Guest Wes Gardner Posted October 9, 2014 Share Posted October 9, 2014 Hi Melynda, Here's the file translated to 2013. Please let me know if you're having issues with this functionality. My email is wgardner@vectorworks.net. I've created a couple of saved views that turn the rcp wall lines on and off on the design layer. There's also a Sheet Layer where, if you click on the viewport and enter the class settings, you can turn Ceiling_Main on and off from there. In the OIP, the "Use Wall Lines" will keep the wall lines ON all the time - not necessarily what you want... 2015 adds even more flexibility in controlling line weight, etc. in your viewports (that's my sales pitch...sorry) Wes Quote Link to comment
gester Posted October 27, 2014 Share Posted October 27, 2014 i've tried to follow the explanations, but i can't make the door lines disappear, or at least change them to dashed lines, no matter if i check 'draw wall lines' or not, and if i turn ceiling-main (ceiling-overhead) class on or off. can anybody help? thx, rob Quote Link to comment
Vectorworks, Inc Employee Vectorworks - Admin Posted October 27, 2014 Vectorworks, Inc Employee Share Posted October 27, 2014 There is no duplicate wall behind it? An easy test for this is to place the door in wall and its associated wall into a new blank file on its own, then do the same test with Draw Wall Lines and altering class visibilities to see if you can get the lines to vanish or change style. If you can do it in the new doc, it usually means duplicate or misclassed geometry in the original. Quote Link to comment
gester Posted October 27, 2014 Share Posted October 27, 2014 jim, thanks for the reply. the wall isn't duplicated, but there is a pilaster modelled as an 'add surface' (depicted on the enclosed file). can it be the cause? rob Quote Link to comment
gester Posted October 27, 2014 Share Posted October 27, 2014 no, it can't be. doors in other walls without pilasters behave the same way... Quote Link to comment
Guest Wes Gardner Posted October 27, 2014 Share Posted October 27, 2014 Here's the file with the wall lines set in the class Ceiling-Main with a line style set to dashed.... Quote Link to comment
gester Posted October 27, 2014 Share Posted October 27, 2014 (edited) wes, thanks a lot, but can you convert it to v2014? actually my line setting in ceiling-main is dashed... rob Edited October 27, 2014 by gester Quote Link to comment
Guest Wes Gardner Posted October 27, 2014 Share Posted October 27, 2014 Here's the file in 2014 Quote Link to comment
gester Posted October 27, 2014 Share Posted October 27, 2014 i'm gradually getting crazy. wes, yours is the same settings as for my door, but the result is like i wanted it to be. where did you set the wall lines to dashed? is it the ceiling-main for door lintel? thx, rob Quote Link to comment
Guest Wes Gardner Posted October 27, 2014 Share Posted October 27, 2014 (edited) Hey Rob, No, you are not going crazy at all. I inadvertently "cheated" and did it in 2015 where I can control these "by Class" - see attached screen shot. I simply told the program to set the wall lines in the Ceiling-Main class and then set the class's line style to dashed. Sorry for misleading you... One of my priorities is to try to get as many items as possible to be controlled by class so that in viewports, you can make stuff look like whatever you want. Hopefully, you can use my door until you get a chance to upgrade! Wes Edited October 27, 2014 by Wes Gardner Quote Link to comment
gester Posted October 27, 2014 Share Posted October 27, 2014 (edited) ok, it's real news for me and a huge difference. apparently there are features in each release that we can't even appreciate enough for its value. rob edit: ok, i've got it. it's the wall lines setting itself. Edited October 27, 2014 by gester Quote Link to comment
sle7en7 Posted May 4, 2016 Share Posted May 4, 2016 I think this is still an issue in VW 2016, where the "draw wall lines" toggle button doesn't function at all. It simply does nothing in my experience, no matter if it's checked or not, wall lines are still drawn and controlled by the "wall lines" door attribute. That's my experience after all, if anybody would like to prove otherwise, please... the stage is yours Quote Link to comment
