seth wilson Posted April 3, 2014 Share Posted April 3, 2014 When i try to enter a value less than 1 degree in the rotation info, it always rounds it to at least 1 degree. How can I enter .5 degrees? If you could point me to tutorials for the following I would appreciate it... How can I zero out the rotation of an object so that its at its original rotation from when it was created? How can I rotate an object on its Z axis while looking at it from the front? Quote Link to comment
Vectorworks, Inc Employee PVA - Admin Posted April 3, 2014 Vectorworks, Inc Employee Share Posted April 3, 2014 File > Document Settings > Units, here on the right you can change the rounding precision for angles. You can zero the rotation of most objects in the Object info palette, the field for "Rotation", if it does not have this field, there is no way that I know of to return it to 0 other than manually rotating it. To rotate it about its Z axis, you can use Modify > Rotate > Rotate 3D, where you can specify the center of the rotation and the axis of rotation. Quote Link to comment
Kevin McAllister Posted April 3, 2014 Share Posted April 3, 2014 Two things - - I think you'll find that it does part degrees even though the field rounds to full degrees after you tab or hit enter. - If its a 3d object, you can reset its rotation back to how it was created using Modify>Unrotate 3d Objects. KM Quote Link to comment
seth wilson Posted April 3, 2014 Author Share Posted April 3, 2014 Cool, Thanks! Quote Link to comment
