lcda Posted March 27, 2014 Share Posted March 27, 2014 is there a way or a script to make automatic dimensions of a simple rectangle? Quote Link to comment
Vectorworks, Inc Employee PVA - Admin Posted March 28, 2014 Vectorworks, Inc Employee Share Posted March 28, 2014 The closest that I know of is the Constrained Dimension tool's "Selected Objects" mode, which you use by selecting the rectangle, enabling this mode with the Constrained Dimension tool, then click once outside or along the edge you want to dimension, then again to set the offset. Saves you having to click corner to corner. This is possible in a more automatic way for Wall objects specifically, via AEC > Dimension Exterior Walls, but that won't work on anything but walls as far as I am aware. Quote Link to comment
