BG Posted March 23, 2014 Share Posted March 23, 2014 Hi This seems like a basic question. Once you have used the fit walls to objects command, what is the best way to reverse this & get the wall back to how it was before this command was run? Thanks Quote Link to comment
CipesDesign Posted March 24, 2014 Share Posted March 24, 2014 You can either double click the wall, then use the "-" sign mode to delete the extra vertices; then pull up or down on corners to bring to desired height. Or create some temporary geometry (like a flat too slab) and use the Fit To command again. Quote Link to comment
