bjoerka
insufficient memory using render bitmap tool
i always get an error when using the render bitmap tool. no matter if rendering is set to opengl or any renderworks setting.
see the attached screenshot.
dpi is set to 72
using the normal render menu works as it should be.
is that a known bug?
Hello bjoerka:
What is the layer scale set to? Is the marquee rectangle very large relative to the page?
The layer scale was set to 1:50
The marquee rectangle is rather small compared to the whole screen.
You can see the size in the new screenshot.
This size starts to render when i lower the dpi setting under 24dpi!
When it does render, what are the dimensions in pixels of the bitmap created, which you can see in the Obj Info palette shape pane?
It doesn?t even start to render. The dialog appears directly after releasing the mouse ;-)
but... when i set the dpi to 20 a size of what you can see in the screenshot show up with 7600px by 8000px in 32bit...
strange. the screen resolution is set to 1920x1200px
Edited by bjoerka
Just another test...
5dpi set for the render bitmap tool
image size generated 12500px by 7850px !
Are you using a retina Macbook Pro? I suspect it might be related to the way the system scales the resolution of the display. This may be confusing what VW is generating.
KM
Of Course i do.
But while working in the office, i use an external display as my primary and keep the macbookpro topcase closed.
So i testes it now with my macbook retina display again and the result is the same.
It seems that VW doesn?t recognize that the external display is running with a different resolution. And of course the dpi settings (to me) seem to work as a multiplier....
Maybe someone from the staff can say something to that..
bjoern
It doesn't use the Retina size to determine the bitmap size in pixels, only the page size. I suspect your page is very small relative to the model. The layer scale determines this, are you sure it isn't set to something like 1:1?
The render bitmap tool's DPI is relative to the page, so that you can generate 300 DPI renderings multiple times, for example. If it were relative to the document window size or something else then the results would change depending on what zoom level you are currently at, which is not as predictable as doing it relative to the page.
We used to have limits from MacOS of a width of 4096 pixels but now we go ahead and try to make the bitmap as large as is requested, so then free memory is the limit.
