Poor plot quality
^ What Benson says.
New sheet layers will be at 72 DPI by default, which is fine for quick screen viewing but no good for a nice plot.
Usually between 150DPI and 300DPI for a sheet layer is fine, any higher and rendered viewports take much longer to complete.
When you create a new sheet layer, if you have the "edit properties after creation" check box checked, a second dialogue opens up. In that dialogue box is a field for setting the DPI for the sheet.
You can also select all of the sheet layers in the organization window and edit them at once after the fact.
