gester Posted February 28, 2014 Share Posted February 28, 2014 hi, the project manager asked me for a record, displaying only one worksheet, containing all building elements with their data fields. it means that the irrelevant or non-existing information isn't populated at all (ignored). the table should contain a mix of all building parts, including walls, symbols, slabs, furniture a.s.o., where rows and columns go in hundreds or thousands. the wish seems a bit strange to me, but it apparently works well with him (there are software packages for project evaluation that work this way, using ifc fields for information source). is something similar possible in vectorworks? if yes, is it a combination of database records and simple excel functionality? thanks in advance, rob Quote Link to comment
michaelk Posted April 17, 2014 Share Posted April 17, 2014 Robert If I understand what you're asking? Yes, this is possible. But, it would be a very large worksheet. You can put as many databases on one worksheet as you want. Is something like this what you are looking for? mk Quote Link to comment
gester Posted May 5, 2014 Author Share Posted May 5, 2014 michael, i've noticed your answer, but i haven't got time to check the result. as i've seen it briefly, the fields (columns) are not the same and vary with each database record. i've actually meant all possible column names that get populated in some records, and not populated in other ones. this would apparently generate much bigger worksheet than the one you've kindly provided. but i'll have to look at this worksheet once again, anyway? thanks, rob Quote Link to comment
