domer1322 Posted February 17, 2014 Share Posted February 17, 2014 I have a file of a 3D building that was started about 5 years ago and i update it regularly. It seems that I frequently notice when I open it that some objects have lost their textures. Then I spend time re-assigning the textures I drew before. I've also noticed some objects changing their 'z' height. It is possible I might have mistakenly changed some class settings or other things to change the textures, but I doubt it. I've seen this behavior on other, older files. Does anyone else have this problem with older files? Is there a way to 'update' a possible corrupted file ? Is there a way to tell if the file is corrupted ? I'm using VW14 on both Windows and Mac. Quote Link to comment
Vectorworks, Inc Employee Vectorworks - Admin Posted February 21, 2014 Vectorworks, Inc Employee Share Posted February 21, 2014 Does it always happen with the same file? Is it a certain kind of object that loses textures, or doesn't seem to matter? any specific textures that are always lost, or does this also seem random? If you can send me one of the older version files where this has occurred, I can test converting it here: tech@vectorworks.net Quote Link to comment
