BG Posted February 9, 2014 Share Posted February 9, 2014 Hi One of our staff has an issue when annotating hidden line section viewports. The viewports are rendered in hidden line, but when the annotations are edited, the viewport switches to wireframe. When the annotation is exited, the viewport reverts back to hidden line. This doesn't happen to me, so not sure what is causing this behaviour? Also, the Site model on the section viewports, shows a lot of triangulated lines. How do you stop this happening? Thanks Quote Link to comment
michaelk Posted February 9, 2014 Share Posted February 9, 2014 When you double click on the viewport to edit and you have the option to choose to edit the annotation, crop, or design layer - at the bottom of that dialog box there is a checkbox for "Display Viewport Cache". Check that. hth mk Quote Link to comment
BG Posted February 9, 2014 Author Share Posted February 9, 2014 Fantastic, that's all it was. Simple. Any clues on why the site model is showing triangulated? Cheers Quote Link to comment
michaelk Posted February 9, 2014 Share Posted February 9, 2014 Assuming you mean in hidden line render mode: Try turning up the Smoothing Angle. Viewport OIP > Background Render Settings? > _________ 20? is often a sweet spot. But try settings between 10 and 30. hth mk Quote Link to comment
BG Posted February 10, 2014 Author Share Posted February 10, 2014 Thanks, that's fixed it. Appreciate your help Brett Quote Link to comment
