mpkeane Posted February 1, 2014 Share Posted February 1, 2014 The way VW is set up, to move a selected object, one can use command + shift + the arrow keys. I would prefer to change that to just command + arrow keys (I think that is the way it used to be?) How can we edit command keys? I can't see how to do that in the workspace editor. Marc Quote Link to comment
mike m oz Posted February 2, 2014 Share Posted February 2, 2014 Marc I don't think you can change it that way because of the pre-existing uses for the command with arrow keys: Command + vertical arrow keys steps you up and down the Layer list. Command + horizontal arrow keys steps you up and down the Class list. Quote Link to comment
Kevin McAllister Posted February 2, 2014 Share Posted February 2, 2014 Marc, You can change it in the Edit pane of the Vectorworks Preferences. There are drop downs for each setting in the bottom right. Kevin Quote Link to comment
Benson Shaw Posted February 2, 2014 Share Posted February 2, 2014 Nudge is working as it always did: Shift Cmd Arrow = move by 10(?) pixels Shift Arrow = move by 1 pixel Or is another nudge required? -B Quote Link to comment
mpkeane Posted February 2, 2014 Author Share Posted February 2, 2014 Thank you Kevin. If only every answer was so painless! Marc Quote Link to comment
