domer1322 Posted January 28, 2014 Share Posted January 28, 2014 can someone tell me how to merge two documents together? That is, if a have 150 resources on one doucment, and another doucment has 200 resources, and about 100 resources are the same on both documents, what is the easiest way to merge all the reources on to one file ? I know how to move individual reasources (import/export) but there must be a easier way than moving them one at a time. Quote Link to comment
CipesDesign Posted January 28, 2014 Share Posted January 28, 2014 With both files open, choose the file into which you want to import the (other file's) resources into. Let's call this the Target File. Make sure that the Target File is the Active (frontmost) file. Now, in the resource Browser (RB), scroll to the other file, to make it the active file in the RB. Shift Select (or Command Select) all of the resources you wish to Import. With all resources selected, choose Resources>Import. Done. Quote Link to comment
domer1322 Posted January 28, 2014 Author Share Posted January 28, 2014 thanks Peter ... I used your directions with ease. This is easy when you know what you're doing ... Quote Link to comment
