Stuart Gray Posted November 13, 2002 Share Posted November 13, 2002 In VW 8.5 it was possible to pick up the cavity wall lines settings from a drawn wall and then "drop" them onto another wall, (ie. one of the same width that was originally drawn without cavity lines). This saved so much time However if I now save a VW8 drawing as a VWA 9 one and then draw a new wall using the Select Wall Type Command I cannot use the Eyedropper tool to pick up the cavity settings from the new wall to then deposit them on a wall drawn previously in VW8. Am I doing something wrong? Quote Link to comment
Guest Posted November 13, 2002 Share Posted November 13, 2002 It looks like in VW 9.5.2/3 you can't do it still. VW 10.0.0 you can. I was able to get it to work in a new 10 document as well as a converted 8 to 10 document. Quote Link to comment
Stuart Gray Posted November 14, 2002 Author Share Posted November 14, 2002 Many thanks for your reply Katie, maybe I should chase up our Distributor over here in England to see when the upgrades are available Quote Link to comment
Guest Posted November 14, 2002 Share Posted November 14, 2002 Stuart, It should be available to you pretty soon. I'm sure one of the guys over at Computers Unlimited will be able to help you out with a projected date. Quote Link to comment
George Cocea Posted November 14, 2002 Share Posted November 14, 2002 quote: Originally posted by Katie: It looks like in VW 9.5.2/3 you can't do it still. VW 10.0.0 you can. I was able to get it to work in a new 10 document as well as a converted 8 to 10 document. In VWA 10, if the wall has a record attached to it the eyedropper tool will not pick up/paint the cavities onto another wall. If the wallrecord is removed then it works. Quote Link to comment
Chris T Posted November 15, 2002 Share Posted November 15, 2002 VW9.5.2 on win 98 I was able to do this in VW9.5.2 Quote Link to comment
The SHP Man Posted January 16, 2004 Share Posted January 16, 2004 I saw your discussion and wondered if you could help. I have been using the VW10.x on Mac OSX since May last year, and I have experienced a number of problems with simple tasks. When I use the dropper tool it locks-up and/or crashes my VW. It is so annoying as firstly, i'm not trying to pick attributes from any complex objects such as text or walls etc. Secondly, this is a very important tool for my work and i am unable to use it. I wondered if anyone know of a remedy to this problem?? Quote Link to comment
Guest Posted January 16, 2004 Share Posted January 16, 2004 Have you run Disk Utility to Verify and Fix disk permissions lately? If you haven't, run that and see if the problem is fixed. If it's not, there could be a corrupt object in the drawing causing the problem .. or some other underlying thing. If Disk Utility doesn't fix the problem, contact tech support at tech@nemetschek.net and have them help you in detail with the problem. Quote Link to comment
