michaelk
3 Script Palette Questions
I need help with 3 questions related to the command
OpenScriptResPal(paletteName :STRING;open :BOOLEAN) ;
and
vs.OpenScriptResPal(paletteName, open)
1. Is there a way to set the screen position and size of the script palettes? I can't find a way to get the dialogID (if there is one).
2. What is the Python command to close a script palette? (It's not 'close', 'closed', 'NOT open', or 'FALSE' !)
3. I don't see a way to GET the open/close status of a script palette. What am I missing?
Thanks!
mk
Trial and error answers question 2!
vs.OpenScriptResPal(paletteName,'') closes a script palette.
New question 2: Why?
mk
I believe it may have to do with how Booleans are represented as bits. A Boolean is only one bit that has a value of 0 (false) or 1 (true). Since the length of the string evaluates to 0, it translates to false.
I know that in lower level languages such as "C", you can use expressions or even functions that evaluate to numerical values in Boolean expressions. A zero is false and anything else is true.
Thanks, Miguel.
I wish there was a VW specific Python language guide. And/Or an additional metric ton of example scripts.
Any ideas about setting the screen position of script palettes?
mk
There will be, Michael, when "we" (meaning "you") finish writing them. ;-) Keep up the good work.
Raymond
