twk Posted January 12, 2014 Share Posted January 12, 2014 This script came into being because our office standard has our room names as trailers of it's dimension. The tedious task was having to select the dimension, navigating to the trailer text box in the object info palette and changing it, then clicking out to regenerate the dimension display. You can use this as a script or create Tool PIO to use it. I've done the latter. Thanks to LarryO for pointing out the Resetobject Procedure Procedure ChangeDimTrailer; VAR h2Dim : HANDLE; x1,y1 : REAL; oldTrailer, NewTrailer : STRING; BEGIN DSelectAll; GetPt(x1,y1); h2Dim:=PickObject(x1,y1); IF h2Dim<>NIL THEN BEGIN CASE GetTypeN(h2Dim) OF 63 : BEGIN oldTrailer := GetObjectVariableString(h2Dim,10); NewTrailer:=STRDIALOG('Type in the New Name for the Trailer', oldTrailer); SetObjectVariableString(h2Dim, 10, NewTrailer); END; END; END; ResetObject(h2Dim); END; RUN(ChangeDimTrailer); Quote Link to comment
