Edit Dimension Trailer
twk
Below is an attempt to write a script that has the user click on a dimension to change its trailer text.
Procedure ChangeDimTrailer;
VAR
h2Dim : HANDLE;
x1,y1 : REAL;
oldTrailer, NewTrailer : STRING;
BEGIN
DSelectAll;
PushAttrs;
GetPt(x1,y1);
h2Dim:=PickObject(x1,y1);
IF h2Dim<>NIL THEN BEGIN
CASE GetType(h2Dim) OF
63 : BEGIN
oldTrailer := GetObjectVariableString(h2Dim,10);
NewTrailer:=STRDIALOG('Type in the New Name for the Trailer', oldTrailer);
END;
END;
END;
SetDimText(h2Dim,Concat(' ',NewTrailer)); {used this instead of setObjectvariable(h2Dim, 10), because that doesnt update the actual dimension object}
PushAttrs;
END;
RUN(ChangeDimTrailer);
Instead what happens is the trailer text gets replaced and is shown however the Show Dim Value in the objInfo pallette is turned off.
Can anyone see why this would happen?
Cheers
Do you have an extra END statement?
There is a limit to the number of characters permitted. Reading from the Function Reference I would say SetDimText is doing exactly what it is supposed to do. Replacing the dimension text.
"Procedure SetDimText will set the dimension text of the referenced dimension to the specified value.
The maximum length for dimension text is 60 characters. The first 30 characters of the specified dimension text string will be displayed in the primary dimension string; the remaining characters will be displayed in the secondary dimension string, if it exists."
Perhaps using SetObjVariableString(Handle,10,'STRING'); followed by ResetObject(Handle);
or SetObjVariableBoolean(Handle,6,TRUE);
Thanks so much Larry, that ResetObject(Handle) did the trick.
I don't believe I have an extra END statement. This works.
Cheers
Upadted Script below
VAR
h2Dim : HANDLE;
x1,y1 : REAL;
{DEBUG}
BEGIN
DSelectAll;
GetPt(x1,y1);
CASE GetTypeN(h2Dim) OF
63 : BEGIN
SetObjectVariableString(h2Dim, 10, NewTrailer);
END;
END;
END;
ResetObject(h2Dim);
END;
Edited by TuiWalker
