gester Posted January 7, 2014 Share Posted January 7, 2014 hi, in what scale do you usually draw in vectorworks (i mean the document settings, i use metric here)? i was accustomed to draw 1:50 in archicad, as it is the scale you can easily go lower or higher, and besides archicad can't scale text (i don't know if it's been improved recently). so the 1:50 seemed to be the universal size to work with. are there any best practice tips for vw in this case? thanks in advance. rob Quote Link to comment
VincentCuclair Posted January 7, 2014 Share Posted January 7, 2014 Well it really doesn't matter, it's only a representation of what you're drawing 1:1 so mainly what feels best for you. If you don't have a specific preference I would suggest using the scale you use most when creating SLVP, this will reduce the amount of scale 'fixing' later on. Quote Link to comment
gester Posted January 7, 2014 Author Share Posted January 7, 2014 thanks vincent, it's what i actually thought. the real reason i ask for the best practice procedures concerns the graphic representation of the architectural drawings, most of all the line weights and hatches (as patterns scale with). is there any recommendation, or is it really of no importance? rob Quote Link to comment
VectorGeek Posted January 7, 2014 Share Posted January 7, 2014 This is excellent advice from Vincent. Draw at the predominant scale that your viewports will be set to. V-G -------------------------------------------------------------------------- VW2013, VW2014 Mac OSX NOT accepted for the Mars One project -------------------------------------------------------------------------- Quote Link to comment
VectorGeek Posted January 7, 2014 Share Posted January 7, 2014 gester: Final output drawing scale is based on a number of things: - type of drawing (plan, detail, wall section, site plan) - size of project (shopping center, SF dwelling) - desired page size (compact or "bed sheet") - available printing technology - bureaucratic requirements - personal preference - eyeglass prescription - not kidding For example, I have done large projects at 3/32" = 1'-0" (roughly 1:120 in metric terms) for floor plans to make them fit on a D size sheet without match lines, which I personally try to avoid. It all depends. V-G. Quote Link to comment
Guest Wes Gardner Posted January 7, 2014 Share Posted January 7, 2014 I also try to set all my hatches to World based... Quote Link to comment
gester Posted January 7, 2014 Author Share Posted January 7, 2014 This is excellent advice from Vincent. Draw at the predominant scale that your viewports will be set to. v-g and this is a good question: we have here the scale for the authorities which is mostly 1:100 for bigger projects, and the execution project is always in 1:50, the details in 1:20 to 1:2. i'm just trying to make the best setting for this. rob Quote Link to comment
VincentCuclair Posted January 8, 2014 Share Posted January 8, 2014 This is partly addressed in this wish list item: http://techboard.vectorworks.net/ubbthreads.php?ubb=showflat&Main=35657&Number=175472#Post175472 Quote Link to comment
