RCrussellUK 0 Posted January 2, 2014 (edited) Hello all, Happy New Year! I'm creating some relatively complex geometry using a lot of intersecting curves and blocks but seem to be achieving this in a rather hit and miss way. In pursuit of good practice I'd like to get a firm grasp of (what I'm sure are fairly simple) modelling principles. The attached file shows the type of thing I'm doing, I need to combine these 3 shapes to create a single extrudable surface. I find it simple to use some arcs, rectangles, circles etc and simple add surface to amalgamate them all. Yet occasionally I have problems joining surfaces, especially when I use a concave arc. Messing about with decompose/compose and switching solid off and on I'm managing to fudge solutions as I go along. This object I push/pulled the three surfaces separately and then added solids to get what I needed. I'm sure there's some simple way to do this that an experienced user would intuitively know. Thanks. Edited January 2, 2014 by RCrussellUK Quote Share this post Link to post
PVA - Jim 2,381 Posted January 2, 2014 The reason these aren't adding together is because the middle object is a 3D Polygon, which is technically flat in this case, but it is still considered by Vectorworks to be a 3D object. You will want to use all 2D geometry to create a flat profile. You can either draw them originally with the (normal)Polygon or other 2D tools, or select the 3D polygon and use Modify > Convert > Convert to Polygons on it. Also, make sure all objects you intend to add surfaces on have a solid fill. The center object had a fill of None. Quote Share this post Link to post
RCrussellUK 0 Posted January 2, 2014 I could have sworn I drew that middle object as a rectangle + arc. Does it convert to a 3D polygon as part of the add surface operation? Quote Share this post Link to post
Wes Gardner 310 Posted January 2, 2014 An easy way to remember: Add and Clip Surface are 2D operations - you'll usually end up with a polygonal shape. 2D stuff typically STAYS 2D stuff... Add and Subtract Solids are 3D operations - you'll usually end up with a Solid Addition/Subtraction. Quote Share this post Link to post
RCrussellUK 0 Posted January 2, 2014 (edited) Another quick one. I draw a shape using a working plane on an angled surface then need to extrude it at 90 degrees to the layer plane rather than the working plane it's drawn upon. There must be a button somewhere to switch the plane the extrusion extrudes from? Is it the second one on the Push/Pull toolbar, but this only seems to work when extruding 3D surfaces not a 2D surface drawn on the surface of a 3D object? Edited January 2, 2014 by RCrussellUK Quote Share this post Link to post
RCrussellUK 0 Posted January 2, 2014 An easy way to remember: Add and Clip Surface are 2D operations - you'll usually end up with a polygonal shape. 2D stuff typically STAYS 2D stuff... Add and Subtract Solids are 3D operations - you'll usually end up with a Solid Addition/Subtraction. Thanks Wes, I think I'm still getting confused at some point about which is which (in terms of drawing 2D shapes with 3D settings) will refine this. On the subject, I seem to remember there is someway to trim away the sub-object info which records the addition/subtraction information for 3D objects. Is this the 'convert to generic solid' option? Quote Share this post Link to post
RCrussellUK 0 Posted January 2, 2014 Apologies for my simple questions, I think this stuff may seem fairly obvious to an experienced VW user, but I'm coming from SketchUp where all this sort of push/pull stuff was straight forwards. Quote Share this post Link to post
PVA - Jim 2,381 Posted January 2, 2014 Yes, Convert to Generic Solids does remove the object's history and combines any contained geometry as well. Quote Share this post Link to post
Wes Gardner 310 Posted January 2, 2014 No need to apologize, these discussions help you as well as other users as well as make it more clear to us where we need to focus our documentation/training/etc. Please, keep asking!!! Quote Share this post Link to post
