sean.simpson Posted December 9, 2013 Share Posted December 9, 2013 I am using Vectorworks 2010 and would like to find out a quick way to change from a white background to a black background without always going into Program Settings. Also, when i have a black background, how can i set up the program so that when i enter the layout area the background is white?? Basically, we use a white background to make design drawings with black lines and a black background to make technical drawings, and the ability to jump quickly between the two would save me a lot of hassel. Any ideas?????? Quote Link to comment
Vectorworks, Inc Employee Vectorworks - Admin Posted December 9, 2013 Vectorworks, Inc Employee Share Posted December 9, 2013 Quick Preferences allows you to toggle it right from the main Vectorworks UI, but unfortunately this feature wasn't added until I believe Vectorworks 2011/2012. In later versions (I think 2012 was the first) you can also set your sheet layers and design layers to have different background colors, if thats what you meant by layout areas. 1 Quote Link to comment
michaelk Posted December 9, 2013 Share Posted December 9, 2013 Back in the day, we used to write little scripts to do jobs like this that were added to the UI after 2010. Here's one that toggles the background between black and white? Just double click it. Not sure what you mean about layout area. Are you trying to set the fill color to white? hth mk Quote Link to comment
sean.simpson Posted December 11, 2013 Author Share Posted December 11, 2013 It seems that exactly what i want is what exists in the newer Versions of Vectorworks, namely the quickpreferences Options and the Background Color preferences. Thanks JimW Michaelk, the Little script is the alternative that i would have then asked for, so thanks for providing it, it works a treat and does exactly what i wanted!! One question, how can i lock the scrip toolbar into my General program layout? somehow i cant embed it in the program layout.... Quote Link to comment
michaelk Posted December 11, 2013 Share Posted December 11, 2013 Are you trying to get the palette to dock? I'm not sure if script palettes can dock. (I assume you are using a Windows machine. - none of the palettes dock on Mac.) mk Quote Link to comment
sean.simpson Posted December 11, 2013 Author Share Posted December 11, 2013 yes, im trying to get it to dock on a Windows machine and it Looks like its not possible. Not the end of the world, at least the script works! Quote Link to comment
Jonathan Pickup Posted December 11, 2013 Share Posted December 11, 2013 I don't think they dock Quote Link to comment
michaelk Posted December 11, 2013 Share Posted December 11, 2013 Back in the 2010 days, many users had a very large palette of preference scripts to do things like that. They are pretty simple to write. If you edit the script in the resource browser you can see how simple they are? Managing all those palettes is an art. On a Mac you can double click the top of the palette to "window shade" it open and closed - so it's out of the way when you don't need it. There must be a similar feature in Windows. Quote Link to comment
dominijk Posted January 13, 2017 Share Posted January 13, 2017 On 12/9/2013 at 4:59 PM, JimW said: Quick Preferences allows you to toggle it right from the main Vectorworks UI, but unfortunately this feature wasn't added until I believe Vectorworks 2011/2012. In later versions (I think 2012 was the first) you can also set your sheet layers and design layers to have different background colors, if thats what you meant by layout areas. @JimWYou mention you can set background by design layer and sheet layer. I've searched for this but am struggling. We are set up with model and print files, the model files are where the drawing happens in design layers with classes making use of colour. I want these to be black. The print file contains just the sheet layer with the model referenced in and classes set to largely black and white , i want these to be white. Which seems like it should be straight forward. Any help gratefully appreciated. Quote Link to comment
Vectorworks, Inc Employee Vectorworks - Admin Posted January 13, 2017 Vectorworks, Inc Employee Share Posted January 13, 2017 33 minutes ago, dominijk said: @JimWYou mention you can set background by design layer and sheet layer. I've searched for this but am struggling. We are set up with model and print files, the model files are where the drawing happens in design layers with classes making use of colour. I want these to be black. The print file contains just the sheet layer with the model referenced in and classes set to largely black and white , i want these to be white. Which seems like it should be straight forward. Any help gratefully appreciated. They're linked if you use Black Background, but if you want separate control of the colors on design and sheet, you can go to Tools > Options > Vectorworks Preferences > Interactive Appearance Settings. There are color controls for General - Background - etc, all done in the Standard tab in your case. Quote Link to comment
dominijk Posted January 16, 2017 Share Posted January 16, 2017 Ah, i see where i was going wrong. Brilliant , thank you. Quote Link to comment
