grant_PD
Automatic drawing coordination update
If you have a viewport, with a drawing label in it, and duplicate it (very very very common when setting up drawings) the sheet number in the drawing label does not change.
It should.
Automatic drawing co-ordination is sort of half implemented. It gets confused by drawing labels directly on a sheet (ie. if I added a reference image to a sheet layer and gave it a drawing label). Or if I renumber a drawing using an existing number it often gives the other drawing the number 1 again, taking it out of sequence.
KM
To reduce Layers, I'll sometime create a viewport with no layers turned on, then annotate it with my detail.
Sometimes I will have 2 Drawing labels in it- that really screws with VW.
