Ian Graham
Scaling text in viewport form external file
If I have a plan in my file and am doing a blow up detail of part of the plan on a saved sheet via viewport , the text is huge .
I can go into Object Info and select Advanced properties and scale text so it looks same as other text. Problem solved.
BUT
If I import a plan from external resource [ another file ] and import the plan into a larger scale , for say , millwork , the text is huge.
Is there a way to control this as we did with above > Object Info and select Advanced properties and scale text so it looks same as other text.
When I do , the dialogue box is limited and doesn't give me the option to scale text . We have been looking on web for answers , but nothing
Any ideas ?
Thanks
Ian
Edited by Ian Graham
Are you importing the file directly as a sheet layer viewport, or importing it onto a design layer, to then create a sheet layer viewport of that?
Perhaps try the opposite of what you are doing to see if that works.
(I hope I am making sense.)
Matt
importing into a design layer, creating a viewport in design layer . For example I am doing a vanity millwork detail , plan , elevations , sections and details , I will import the plan from the architectural file . I will try doing everything as viewports in saved sheets to see if I can remedy this.
Thanks !
Ian
