Yovav Posted October 31, 2002 Share Posted October 31, 2002 In VW 8.5.x I was used to set my perspective by numbers - VIEW > PERSPECTIVE > SET PESPECTIVE. This procedure is a must if you want to implant your rendered image inside a photo (for example: implanting a new building, rendered by RW, between two existing buildings, shown in a photograph). In 9.5.2 this feature exists, but after changing the value in the dialog box, there is no effect on the 3D view. The 3 preset values: NARROW, NORMAL and WIDE are working fine, but you loose the range between them. In my case I had to take the 3D model down to 8.5.x, set the correct view, and take it up again to 9.5.2. Of course I lost a lot of data in this annoying procedure, like textures etc. Any solutions for this bug? Quote Link to comment
P Retondo Posted November 1, 2002 Share Posted November 1, 2002 Yovav, What platform do you use? I have no problem resetting perspective in 9.5.2 (WinXP and Win2000). Works beautifully (View->Perspective->Set Perspective). Quote Link to comment
Yovav Posted November 3, 2002 Author Share Posted November 3, 2002 This is odd. I got the same - 9.5.2 + XP Quote Link to comment
