VvierA Posted November 18, 2013 Share Posted November 18, 2013 Very strange: If I try to 'SetView(0,0,30,1,1,1)' nothing happens. If I try 'SetView(0,0.001,30,1,1,1)' it works. Can anybody explain? Why isn't it possible to just rotate the z-axis? VvierA Quote Link to comment
DeSignature Posted November 20, 2013 Share Posted November 20, 2013 Not really, no. However, it is possible to rotate the workplane-Z-axis, Exporting an empty file as a script shows me this in the code when the working plane is rotated over 45?: (...) {Layer Characteristics} (...) Projection(0,0,1239.519999999999982,-619.759999999999991,619.759999999999991,619.759999999999991,-619.759999999999991); SetView(#0.0000000000000d,#-0.0000000000000d,#0.0000000000000d,0,0,0); {End of Layer Characteristics} {Object Creation Code} SetView(#0.0000000000000d,#-0.0000000000000d,#0.0000000000000d,0,0,0); SetZVals(0,0); (...) So maybe it might be worthed looking into the SetView-parameters (?) Quote Link to comment
MullinRJ Posted November 25, 2013 Share Posted November 25, 2013 If I try to 'SetView(0,0,30,1,1,1)' nothing happens. It works on my machine. How about adding a signature? It's hard to guess how you are working. And while you're at it, how about some relevant details about your problem? Are you running a script? A PIO? A menu command? Usually I skip questions like this because they are too vague. You just caught me in a good mood. :-) Raymond Quote Link to comment
