bjoerka Posted November 15, 2013 Share Posted November 15, 2013 (edited) Not sure if this is working like it should.Take a 3d model and turn on "view - clip cube", rendering set to open-gl.Everything seems fine.Switch to "view - rendering - any renderworks"Now the clip cube is ignored and the whole model is visible. At this point i am not sure if this is correct or clip cube only works on wireframe and open-gl.Now switch back to open-gl. The bounding box of the clip cube is displayed in light grey, but the whole model is rendered and visible.Turning the view with the flyover tool does not change anything.Switch back to wireframe and now only the inside area of the clip cube is displayed like suggested.Feature or bug? .-)Best,bjoernclip cube with open-gl [img:left]http://www.kantereit.de/vw/cc-opengl1.png[/img] clip cube with renderworks [img:left]http://www.kantereit.de/vw/cc-renderworks.png[/img] clip cube with open-gl again [img:left]http://www.kantereit.de/vw/cc-opengl2.png[/img] clip cube with wireframe [img:left]http://www.kantereit.de/vw/cc-wireframe.png[/img] Edited November 15, 2013 by bjoerka Quote Link to comment
Christiaan Posted November 15, 2013 Share Posted November 15, 2013 Yeah I get the same behaviour. Seems like a bug to me. Quote Link to comment
bjoerka Posted November 15, 2013 Author Share Posted November 15, 2013 so let?s hear what Jim says about it... Quote Link to comment
Vectorworks, Inc Employee PVA - Admin Posted November 15, 2013 Vectorworks, Inc Employee Share Posted November 15, 2013 According to the Help documentation, Clip Cube only works in Wireframe and OpenGL currently, so that part is working as designed. However when the rendering mode is switched back to OpenGL, i would expect it to resume the Clip Cube view right away. I'll make sure I can replicate the problem here and if so, submit it as an issue. Quote Link to comment
bjoerka Posted November 15, 2013 Author Share Posted November 15, 2013 Ok. I just sent you the file that i was working with. Quote Link to comment
Vectorworks, Inc Employee PVA - Admin Posted November 15, 2013 Vectorworks, Inc Employee Share Posted November 15, 2013 Confirmed the same odd behavior, submitting as an issue now. Quote Link to comment
bjoerka Posted November 15, 2013 Author Share Posted November 15, 2013 Top. Thank you! Quote Link to comment
