3D objects
New here and new to Vectorworks. If I had a lot of time, I might be able to figure this out, but I'm hoping to use Vworks in my current project. I have been trying to figure out how to create a 3D polygon that is sloped (has different Z values for various vertical lines on the vertices.) The 3D and extruded poly tools only seem to make level polygons. Is there a way to do this with Vworks 8? Do I need some plugin or an upgrade of some kind? Or is there a trick? Any help would be greatly appreciated. Thanks.
quote:
Aside from the previously mentioned ways of doing this, you can also adjust the working plane to be at the required angle, and the 3-D tools will work with that. (See the set working plane tool docs for more information.)
