Sam Lee Posted November 7, 2013 Share Posted November 7, 2013 We have a drawing we did the other day which was half drawn in 'Top/Plan' and half drawn in 'Front', this was done by mistake, is there a simple way we can take the drawing from 'Front' and move it to 'Top/Plan' ? Quote Link to comment
Jim Smith Posted November 7, 2013 Share Posted November 7, 2013 LLI: - Have you used the Wall PIO? - Is this 2D or 3D drafting? - May this just be a case of changing the View option in the Viewport? Quote Link to comment
Sam Lee Posted November 7, 2013 Author Share Posted November 7, 2013 Hi Jim, When you say the 'Wall PIO' do you mean the wall tool in the Tool sets ? Its 2d drafting but was drawn in the 'Front' current view. - the problem with that is that half the drawing is in 'Top/plan' and half in 'front' so that when we try to view all the drawings together on the design layer we cant as they are in different current views. I could just change it on the viewport, which would work for exporting individual drawings as pdfs or to print, but again the issue is that i cant see and make decisions on all my drawings in the design layer as they are in different current views. Quote Link to comment
Jim Smith Posted November 7, 2013 Share Posted November 7, 2013 LLI Yes the Wall Tool is what I was referring to. Ahh, I think I know what you mean, I think this is a Layer Plane Issue. In the Object Info Pallet are your objects on Layer or Screen Plane? What you should be able to do is select all your objects drawn in Front View, then change your view to Right or Left, then rotate the objects so they now are in Plan View. This may take some Rotating or moving but that should fix the issue. Quote Link to comment
Benson Shaw Posted November 7, 2013 Share Posted November 7, 2013 2d objects have a screen/layer setting (plane mode) in the OIP. The drawing has separate a screen/layer setting in the menu bar. Try this on your Front view objects (should work individually or in bunches, or all at once, but test on a single one first): Set the drawing to Layer Plane mode. Switch drawing to Front view Select the Front view objects In the OIP, toggle the plane mode to Screen Switch drawing to Top/Plan In the OIP, toggle the plane mode to Layer Keep the objects selected, because you may have to relocate them to align with the objects drawn in Top/Plan. Quote Link to comment
Bruce Kieffer Posted November 8, 2013 Share Posted November 8, 2013 Are you sure it's not just as simple as: Make the view front view, select the objects that were drawn in front view, group them, cut the group (command X), switch to top view, paste the group. You will probably need do some aligning of objects. Don't ungroup until everything is aligned. Quote Link to comment
