Kevin McAllister Posted October 29, 2013 Share Posted October 29, 2013 Can anyone tell me what's going on here? Top image is fine - wireframe mode while editing a symbol. Bottom image has a crazy repeat of the symbol contents - OpenGL mode while editing the same symbol. Kevin Quote Link to comment
Teresa Hull Posted October 30, 2013 Share Posted October 30, 2013 I had a similar issue a few days ago. I had to redraw it. Quote Link to comment
Elite Exhibits Posted October 30, 2013 Share Posted October 30, 2013 I have noticed this Bug for some time. If you are Editing inside a Group or inside a Symbol, and Rendered (Open GL) then the oddities start. The hint at this is a shape that appears to be sliced through by an imaginary plane. Peter Quote Link to comment
Vectorworks, Inc Employee PVA - Admin Posted October 30, 2013 Vectorworks, Inc Employee Share Posted October 30, 2013 Could anyone experiencing this attach an example VWX file where it is actively occurring, please? Quote Link to comment
Kevin McAllister Posted October 30, 2013 Author Share Posted October 30, 2013 Peter, You're describing exactly what I'm seeing. Jim, I can't post that file here but I can send it to you. Kevin Quote Link to comment
Vectorworks, Inc Employee PVA - Admin Posted October 30, 2013 Vectorworks, Inc Employee Share Posted October 30, 2013 Thank you, i'll keep an eye out. Quote Link to comment
Vectorworks, Inc Employee PVA - Admin Posted October 30, 2013 Vectorworks, Inc Employee Share Posted October 30, 2013 (edited) I get the same results when I open your file directly, however it works fine when all geometry is copied out and pasted into a new document, though the file's history seems to have elements from as far back as 12.5. Was this document originally made with that version or is it possible you have a template file that dates from that era? As a test, if you use this procedure: http://kbase.vectorworks.net/questions/790/Layer+Import To bring all the geometry/design layers into a new blank document, not from a template, what occurs? Edited October 30, 2013 by JimW Quote Link to comment
