Kevin McAllister Posted October 24, 2013 Share Posted October 24, 2013 (edited) Can someone tell be why these two different EAPs show up differently in section? The EAP profiles are all similar types of objects yet some get hatched and some don't. Part of the issue seems to be caused by objects that cross the x axis zero point within the profile. Removing that one object helps but doesn't fix things entirely. My current project has quite a few EAPs and this is one of a few issues I'm trying to solve. Any insight would be appreciated. Kevin Edited October 24, 2013 by Kevin McAllister Quote Link to comment
Guest Wes Gardner Posted October 24, 2013 Share Posted October 24, 2013 On the "unhatched" profile, if I "Add Surface" the two profile objects - the rectangle and the sculpted shape, all is well... Quote Link to comment
Kevin McAllister Posted October 24, 2013 Author Share Posted October 24, 2013 Thanks Wes. That's a good workaround but I would prefer to keep the profiles separate if possible. I would also love to understand why this particular geometry is different. Perhaps this is a bug then? Since clearly multiple shapes are possible?. Kevin Quote Link to comment
Guest Wes Gardner Posted October 24, 2013 Share Posted October 24, 2013 (edited) How 'bout this...if you zoom way in, the profiled section is separated from the main square shape whereas the shapes, etc. on the left are all touching and therefore are homogenous...is that the right word??? Edited October 24, 2013 by Wes Gardner Quote Link to comment
Guest Wes Gardner Posted October 24, 2013 Share Posted October 24, 2013 And then if I move the sculpted object out, I get this...seems there's something going on with the multiple profile objects and EAP... Quote Link to comment
Kevin McAllister Posted October 24, 2013 Author Share Posted October 24, 2013 (edited) Yup. Its definitely a bug. Two objects can't touch as far as I can tell. As soon as they do one of them won't hatch correctly in section. The objects on the left in my original image actually have the same problem, they're just too small for it to show and I didn't notice. Kevin Edited October 24, 2013 by Kevin McAllister Quote Link to comment
