Hippocode Posted October 22, 2013 Share Posted October 22, 2013 In vectorworks 2013 the standard space tool has an organised OIP. Is it possible to code such dividers trough vectorscript ? Quote Link to comment
Vectorworks, Inc Employee klinzey Posted October 22, 2013 Vectorworks, Inc Employee Share Posted October 22, 2013 You can use vsoInsertWidget() with a widgetType of 100 to insert a separator into the OIP. I updated the widget list in the wiki to list all the currently available widgets, there were several missing. Quote Link to comment
Hippocode Posted October 23, 2013 Author Share Posted October 23, 2013 (edited) You can use vsoInsertWidget() with a widgetType of 100 to insert a separator into the OIP. I updated the widget list in the wiki to list all the currently available widgets, there were several missing. Thanks for pointing that out, do you also know how parameters under such a divider get their padding ? I tried adding spaces into the string which worked but not for radiobuttons etc.. Also, these were non responsive: kWidgetBoundPopup = 102; kWidgetBoundOffset = 103; What do they do ? Edited October 23, 2013 by hippothamus Quote Link to comment
Vectorworks, Inc Employee klinzey Posted October 23, 2013 Vectorworks, Inc Employee Share Posted October 23, 2013 Use vsoWidgetSetIndLvl() to indent the parameters in the OIP. kWidgetBoundPopup = 102; kWidgetBoundOffset = 103; Should work, they are in use by other VS objects. They are used in conjunction with stories so that the object can respond to changes in the story settings. Quote Link to comment
