VW2014 'Center Mark' Tool Question
Did something change in 2014 that prevents me from applying a Center Mark from the Dimensions/Notes Tool Bar to a hole on a part inside of a Viewport?
After you go and 'Edit Annotations' to get into the viewport you can select the Center Mark tool, then the hole's circle turns red when you move the cursor over it, select the hole with the mouse, but the center mark does not appear.
