After almost a year of using VW for 3D printing, here are some items for the VW wish list -
Basic STL Export Improvements
- rename this export "Export STL" instead of "Export Stereo Lithography" to bring it in line with standard terminology used in other software packages.
- add the ability to choose mm or inches in the export dialog (see image).
- add the ability to scale the model that is exported including options for none, current layer scale (STL only exports the current layer), standard architectural scales or a custom scale (see image).
Advanced STL Export Improvements
- in an idea world this dialog would also give you a polygon count or a visual representation of the number of polygons.
- this dialog would give the option to "wrap" the geometry, removing all internal structures (see netfabb Wrap Part Surface or Autodesk Project Miller Surface).
- some error checking including flipped triangles (see my solids wish which details some of the errors VW creates), mesh holes etc.
Other wishes
- The ability to make the "page" in the design layers into a 3D plane as reference for a 3d printer's build platform. Ideally I could choose 3D printer in Page Setup to turn this on/off. (Right now I'm using a custom page size that matches the build platform but it only works as a reference in Top/Plan).
The industry is shifting quickly and in a short time it will be clear if STL is replaced by 3MF (Microsoft's 3D Manufacturing Format).
Kevin McAllister
Other wishes
Kevin
10 answers to this question
