rsa Posted October 13, 2013 Share Posted October 13, 2013 I just installed 2014. When I select a group, symbol or viewport it looks like an opaque block. Anyone else have that problem. I did a quick search of the forum and didn't see any other posts on this. I attached an image with nothing selected and an image with a group selected. I'm finding this to be a big problem. Thanks, Rob Quote Link to comment
Bruce Kieffer Posted October 13, 2013 Share Posted October 13, 2013 That's strange. Don't see the problem on my setup. Does it happen in all of your files? Maybe it's some setting in your interactive display prefs. Quote Link to comment
rsa Posted October 13, 2013 Author Share Posted October 13, 2013 All files. I've looked in interactive display prefs and can't find anything that helps. does this on both my computers. These are all files from 2013. I'll try a new file... Quote Link to comment
rsa Posted October 13, 2013 Author Share Posted October 13, 2013 If I turn off selection highlighting the problem goes away... Seems like this pretty much makes 'selection highlighting' unworkable. I'll turn it off for now. Quote Link to comment
BiztroBill Posted October 13, 2013 Share Posted October 13, 2013 I'm on a Mac, but it's probably similar. If you go to your Vectorworks Preferences window, click the Interactive tab, and then the Interactive Appearance Settings, select one of the Object Highlighting elements. When it's selected, you get choices for setting colors and opacity. The default appears to be about 40% opacity. Is that what yours looks like? Quote Link to comment
rsa Posted October 13, 2013 Author Share Posted October 13, 2013 Interesting. I think it is a bug in the 'object highlighting-active layer' setting. Changing opacity does nothing. If I change the fill then the selected opaque group object changes to the new fill. I just opened VW2013 which with the exact same settings - selection highlighting 'on' and the same 'object highlighting-active layer' setting yet selected groups are visible. in VW 2013 turning up or down the opacity controls the opacity of the objects in the selected group. I'll report this as a bug if I can figure out how... Quote Link to comment
Bruce Kieffer Posted October 13, 2013 Share Posted October 13, 2013 Call tech support. They can help. Quote Link to comment
Vectorworks, Inc Employee PVA - Admin Posted October 14, 2013 Vectorworks, Inc Employee Share Posted October 14, 2013 (edited) Yes, please contact support. This issue is normally graphics card related: http://kbase.vectorworks.net/questions/1171/Solid+orange+highlighting+on+Viewports%2C+Symbols%2C+and+Groups+etc Edited October 14, 2013 by JimW Quote Link to comment
rsa Posted October 14, 2013 Author Share Posted October 14, 2013 I did contact tech support. Apparently my new computer was not using the nvidia graphics card for VW it was using the integrated graphics instead. Annoying! Here is the tech support email in case anyone has a similar issue... This is most likely what you are experiencing: http://kbase.vectorworks.net/questions/1171/Solid+orange+highlighting+on+Vi ewports%2C+Symbols%2C+and+Groups+etc. -Jim Technical Support Specialist Nemetschek Vectorworks Quote Link to comment
