Neil's in... Posted October 8, 2013 Share Posted October 8, 2013 Hi all, I'm excited to finally have an account on here after reading many great threads that have been very helpful! I've searched various forums (including this one) and have not yet seen this question, without further ado. The problem I'm finding, the current project I'm working has a couple of three sash windows in a row, the two outer are half the width of the central. The glazing bars/muntins are divide equally across all three windows, I see you can exclude the glazing bars from a pane but not change the ratio. Has anyone got an answer to overcoming this? Attached is an image of what I'm trying to achieve. Presently I've suck two single sashes side on to the larger sash to achieve my goal, but am not happy with this result. Quote Link to comment
Vectorworks, Inc Employee Vectorworks - Admin Posted October 8, 2013 Vectorworks, Inc Employee Share Posted October 8, 2013 I just tried to do this here and couldn't complete it either. The unequal sashes weren't a problem when using the Custom sash style, but you're right, the muntins aren't individually controllable. I was able to recreate the same sash configuration as your image, but then the muntin sizes could either all match or be disabled, which was incorrect. If anyone has figured out a way to do this, please let us know. Otherwise ill move this to a wishlist request. Quote Link to comment
Neil's in... Posted October 9, 2013 Author Share Posted October 9, 2013 Hi there JimW, This is the current work-around I'm settling for, however, as you can imagine it's far from perfect. Quote Link to comment
CipesDesign Posted October 9, 2013 Share Posted October 9, 2013 Yes this is a real problem. Although we can create a Custom Config Window with the three accurately sized "Columns", there is currently no way to set the Muntins such that the spacing is even. What we need to is more control over the muntins in each column of the custom window... Quote Link to comment
Archiphreak Posted October 21, 2013 Share Posted October 21, 2013 You would think this fairly easy within the Custom Window dialog. Perhaps the VW boys can put this in 2015. Another option that I see is to create the 3 windows separately (center window without jamb) and create a new symbol saved to your library. Quote Link to comment
