Cloud Hidden Posted October 16, 2002 Share Posted October 16, 2002 Is anyone aware of a piano object--upright or baby grand? I always have trouble trying to find objects in the browser. Thanks. Quote Link to comment
Guest Posted October 16, 2002 Share Posted October 16, 2002 We don't have a piano symbol. Quote Link to comment
AndyM Posted October 16, 2002 Share Posted October 16, 2002 I have two baby grand symbols. One native VW that is pretty cheesy and one converted from 3ds that is very good, but lots of polys. If you want them I will email them to you. Quote Link to comment
jfmarch Posted October 17, 2002 Share Posted October 17, 2002 I had this problem some time ago. I eventually drew a baby grand in 2D. But you might try these two sites: Vectordepot, which has great VW stuff to download or 3D Cafe which has 3D stuff. Good luck. 3D Cafe VectorDepot Quote Link to comment
Cloud Hidden Posted October 29, 2002 Author Share Posted October 29, 2002 Thanks! OK, so I download a piano.mcd from VectorDepot and put it in the Object Libraries folder, but VW doesn't recognize it as a VW file and neither does Finder. Whatcha gotta do to make it usable? OSX 10.1.5 VW 9.5.2 Quote Link to comment
Guest Posted October 29, 2002 Share Posted October 29, 2002 Make sure it has a .mcd at the end of the file if you are on a PC. I would open the file straight in VW, then save it as a VW file just in case it's from an earlier version or something like that. If the symbol is from an earlier version of VW, you won't be able to use the symbol until it's converted to the current version you are using. Quote Link to comment
Ian M. Posted October 25, 2018 Share Posted October 25, 2018 OK, it is 2018, now and there is still no Vectorworks piano symbol? Quote Link to comment
Vectorworks, Inc Employee JustinVH Posted October 25, 2018 Vectorworks, Inc Employee Share Posted October 25, 2018 There are two piano symbols in the Resource Manager and I found them by using the search function for 'piano'. Quote Link to comment
Ian M. Posted October 25, 2018 Share Posted October 25, 2018 I confess that I am new to the Resource Manager, having only just upgraded from 2013, but I have watched the video tutorial, have turned on every resource option in the Resource Manager, and I get a variety of Forbo linoleum samples, and a Johanson bar stool - no piano. Can you tell me exactly which resource folder it is in? Quote Link to comment
Vectorworks, Inc Employee JustinVH Posted October 25, 2018 Vectorworks, Inc Employee Share Posted October 25, 2018 Are you running an Architect only license or Designer? The piano is in the Objects-Ent Stage folder but that is limited to Spotlight or Designer. It looks like you have Vectorworks Service Select from your screenshot. If this is the case you can download the piano symbols from the VSS website. The pianos are in the Previous Versions>Entertainment>Orchestra Layouts 3D folder. Let me know if you have any questions. Quote Link to comment
Ian M. Posted October 25, 2018 Share Posted October 25, 2018 1 hour ago, JustinVH said: Are you running an Architect only license or Designer? The piano is in the Objects-Ent Stage folder but that is limited to Spotlight or Designer. It looks like you have Vectorworks Service Select from your screenshot. If this is the case you can download the piano symbols from the VSS website. The pianos are in the Previous Versions>Entertainment>Orchestra Layouts 3D folder. Let me know if you have any questions. @JustinVH I confess that, so far, I am not hooting and hollering about how the Resources Manager works. I used the "Help_Download Content" menu to get the "Spotlight Libraries - Entertainment Objects Libraries". The file successfully downloaded onto my computer, and I can now see that I have "Orchestra Layout 2D.vwx" and "Orchestra Layout 3D.vwx" in my "Vectorworks_Libraries_Objects - Ent Stage" folder, but searching in the Resources Manager does not turn up the files with "piano"?! (see attached "Piano2.png) I used the "Browse a Document" menu to look at the "Orchestra Layout 2D.vwx" file, and finally the 2D piano images showed up in the Resources Manager, but the 3D files that I know are on my computer, in the Vectorworks libraries, still do not show up. That doesn't seem very effective to me. Am I missing something? Quote Link to comment
Ian M. Posted October 25, 2018 Share Posted October 25, 2018 @JustinVH I am enclosing a screenshot showing the Resource Manager window with "piano" typed into the search bar. There are only two pianos shown in the results. In the lefthand column of the Resource Manager, the folder under "Vectorworks Libraries_Objects - Ent Stage" only shows two files (see "piano4.png"), but using my computer's "Finder" window, I see 12 different files under the same "Vectorworks Libraries_Objects - Ent Stage" file structure (see "Piano5.png"). What is the explanation for that? Why can't the Resource Manager see those files? Quote Link to comment
Vectorworks, Inc Employee JustinVH Posted October 25, 2018 Vectorworks, Inc Employee Share Posted October 25, 2018 @Ian M.I am not sure why those remaining files are not visible in the Resource Manager. Have you tried closing and reopening Vectorworks to see if it resolves the issue? Perhaps @JimW can provide more information. I have attached two files with pianos for your use, you should be able to just open them and import the piano(s) you desire into your drawing. Musical Instruments.vwx Orchestra Layout 3D.vwx Quote Link to comment
R Buckingham Posted February 12, 2020 Share Posted February 12, 2020 On 10/25/2018 at 3:42 PM, JustinVH said: @Ian M.I am not sure why those remaining files are not visible in the Resource Manager. Have you tried closing and reopening Vectorworks to see if it resolves the issue? Perhaps @JimW can provide more information. I have attached two files with pianos for your use, you should be able to just open them and import the piano(s) you desire into your drawing. Musical Instruments.vwx Orchestra Layout 3D.vwx These files / links are no longer valid. How do I find these symbols? Why are they not part of spotlight to begin with? Quote Link to comment
DBruhnke Posted February 13, 2020 Share Posted February 13, 2020 @R Buckingham Just downloaded these 2 files and they open in VW 2020 fine. Both have symbols in them. What are you looking for exactly? Quote Link to comment
jmhanby Posted September 9, 2022 Share Posted September 9, 2022 On 10/25/2018 at 1:11 PM, Ian M. said: I confess that I am new to the Resource Manager, having only just upgraded from 2013, but I have watched the video tutorial, have turned on every resource option in the Resource Manager, and I get a variety of Forbo linoleum samples, and a Johanson bar stool - no piano. Can you tell me exactly which resource folder it is in? I am looking for the upright piano and all I get is this same screen. Can anyone help me out? Quote Link to comment
jmhanby Posted September 9, 2022 Share Posted September 9, 2022 I did update the libraries and my employer doesn't have Spotlight license. Quote Link to comment
DBruhnke Posted September 12, 2022 Share Posted September 12, 2022 On 9/9/2022 at 3:42 PM, jmhanby said: I am looking for the upright piano and all I get is this same screen. Can anyone help me out? Be sure your libraries are up to date. Right click on the Premium Libraries and "Refresh" Do the same for the Vectorworks Libraries Make sure that your search is for everything, everywhere. I'm seeing several results for "piano" Note the little cloud and arrow in the bottom left corner of each symbol. This means that it's currently in the cloud and will need to download to use. HTH Quote Link to comment
