The smoothing angle addition to Hybrid objects in v2014 is, I'm sure, a fine bit of programming. However it's fallen at the first hurdle when I've tried to use it.
We often model balcony handrails using the extrude along path command. More often than not these hand rails are circular. And we would have liked to use the smoothing angle feature to display the handrail in plan view without any facets. The problem is it doesn't matter what angle you use at least one facet remains showing, as attached image.
So frustrating. Why do these sorts of things always creep in? Surely you have a loads of architects helping you beta test and check new features before release? Another year until this is fixed or should I submit a bug?
Christiaan
8 answers to this question
