JBD Posted September 16, 2013 Share Posted September 16, 2013 I was working in my lighting plot at 1/2"=1'-0" Not exactly sure what I did but the scale is set to 1/2" but non of the dimensions are correct to what they should be. Any advice would be helpful. Thank you. Joe Quote Link to comment
michaelk Posted September 16, 2013 Share Posted September 16, 2013 Did you import an image, pdf, or dwg and scale that object? It's possible that "Entire Drawing" was checked. If that's what happened you can use the scale object command again and do a "symmetric by distance" to a known distance. hth mk Quote Link to comment
Vectorworks, Inc Employee PVA - Admin Posted September 16, 2013 Vectorworks, Inc Employee Share Posted September 16, 2013 It's possible that "Entire Drawing" was checked. If that's what happened you can use the scale object command again and do a "symmetric by distance" to a known distance. This is most likely the case. Using Scale by Distance is detailed here: http://kbase.vectorworks.net/questions/449/Scale+by+Distance Quote Link to comment
