MaskMan Posted September 14, 2013 Share Posted September 14, 2013 I am trying to design a life size version of the mountain Jack Skelington walks on in A Nightmare Before Christmas theme Company party. I have never used nurbs and any tutorials you may know of, links, pdfs would be greatly appreciated. [img:center]http://pichost.me/1459208/[/img] Quote Link to comment
michaelk Posted September 14, 2013 Share Posted September 14, 2013 I never want to discourage anyone from learning about NURBS, but I don't think NURBS are necessary for this shape. You might be able to slide by with an EAP... mk Quote Link to comment
MaskMan Posted September 15, 2013 Author Share Posted September 15, 2013 What version of Vectorworks is your attachment? I have 12 and it won't let me open it. Quote Link to comment
michaelk Posted September 15, 2013 Share Posted September 15, 2013 Here it is in v 12. Please add your VW version to your signature hth mk Quote Link to comment
MaskMan Posted September 15, 2013 Author Share Posted September 15, 2013 Wow, nice. Did you draw a spiral and a circle then EAP? My colleagues and I couldn't figure out how to do the taper of the spiral. Thanks I appreciate all the help you are providing. Quote Link to comment
michaelk Posted September 15, 2013 Share Posted September 15, 2013 (edited) I tried a spiral first, but it was too regular. So I just drew a polyline and a circle and made an EAP. After that, it took a little futzing around with the size of the circle profile and the exponential shape factor. If you really want to have a NURBS experience, this will get you a more precise result. 1. In Screen Plane, Front View: trace the inside and outside edges of the mountain profile with the polyline tool. Convert both of them to NURBS. In the OIP, check show direction. Make sure the direction of both is from the bottom to the top. 2. In Layer Plane top plan or 3D view. Draw a circle approximately the diameter of the bottom of the mountain. Convert to NURBS. 3. 3D Tool set. Loft Tool. 3rd mode. (Birail loft). Click on the first two shapes and then on the circle. Click the green checkmark. In the next dialog box Check Create Solid and Keep Curves. -If you don't check Create Solid you will get a group of NURBS Surfaces. Probably a lot of them. -If you don't check Keep Curves there are no second chances. Loft surface isn't editable afterwards. So keep the original curves if you want to edit them and try again. Click OK. hth mk PS. Probably important to mention in step 1: Don't let the polylines touch at the "top" of the mountain. Edited September 15, 2013 by michaelk Quote Link to comment
MaskMan Posted September 15, 2013 Author Share Posted September 15, 2013 Thanks, I'll get to practicing. Quote Link to comment
James Russell Posted September 18, 2013 Share Posted September 18, 2013 Bumping Michael's awesome NURBS demo, makes it less of a Nightmare for sure! Quote Link to comment
mike m oz Posted September 18, 2013 Share Posted September 18, 2013 The 3D Power Pack area contains useful information on nurbs: Movies: http://www.vectorworks.net/3Dpowerpack/tutorials.php Tutorials: http://www.vectorworks.net/3Dpowerpack/tutorials.php Tips and Tricks: http://www.vectorworks.net/3Dpowerpack/tips.php etc. Quote Link to comment
MaskMan Posted September 25, 2013 Author Share Posted September 25, 2013 Thanks Mike! Quote Link to comment
