Vik Asrani Posted October 14, 2002 Share Posted October 14, 2002 Hi All I am using VW 9.0.1 on a Mac G3 with os 9.1. When exporting a drawing to JPEG format, I lose some of the image lines. I am doing a basic 2d line drawing for use in a brochure and seems like the JPEG export is not centered like the drawing is in VW. I have tried increasing the size of the exported image but this does not change anything. The only thing that works is to guess where the image shoudl be and moving it in VW then exporting. Any ideas on what to do to not have this extra step? I have updated QT to 6.0 and this problem is still there. I ahvent tried other image formats though. Any and all help is greatly appreciated. TIA. Vik. Quote Link to comment
Bryan_dup1 Posted October 15, 2002 Share Posted October 15, 2002 I had the same problem a couple months ago, you need to update to 9.5.2, which is the last non-beta version 9. If your drawing is 2d then set your view to persepctive and use the adjustable window to size the drawing to export to .jpg The combination of one or both above should fix your problem. Quote Link to comment
Guest Posted October 15, 2002 Share Posted October 15, 2002 QT 6 is going to give you a separate set of problems. Either revert back to QT 5 in conjunction wtih updating to VW 9.5.0. Or update to VW 9.5.3b2. Here is the link to revert to QT 5 - http://docs.info.apple.com/article.html?artnum=61621 Quote Link to comment
