gester Posted September 27, 2013 Share Posted September 27, 2013 digitalmechanics, i understand less than before. your ifc data dialog has material data checked and populated (have you inserted the word 'concrete' manually ??), but the dimensions in the solibri model viewer are set at 'zero', and you don't have any record data fields populated in the object info dialog (tab data) in the vw file. as i see the only issue of your ifc data that is richer than in mine is the material tab in the ifc data and the material description. to see the results i will have to wait for the material data entry check in the external estimation software. it will last a while. what's going on here? i'm confused... rob Quote Link to comment
digitalcarbon Posted September 27, 2013 Author Share Posted September 27, 2013 yes i added concrete no i do not have any vw records data attached i was adding lots of info in the ifc dialog box but have stopped. it is not needed to export to ifc and i was losing the data when i had to modify the 3d object Quote Link to comment
Vectorworks, Inc Employee Robert Anderson Posted September 27, 2013 Vectorworks, Inc Employee Share Posted September 27, 2013 Mike, why do you ask someone else to "send the file to tech support"? You can do this.. Quote Link to comment
gester Posted September 28, 2013 Share Posted September 28, 2013 (edited) actually i don't know if it's a bug or a feature. somehow the data must be populated in the ifc export file in order for the estimation and simulation softwares to retrieve it. and somehow the automated vectorworks ifc export seems to miss it. so is my impression for today. rob edit: and how about the ifc data exchange with ies virtual environment? Edited September 28, 2013 by gester Quote Link to comment
digitalcarbon Posted October 4, 2013 Author Share Posted October 4, 2013 ifcMe- 7.0 - ifc object management need a way to tell what is ifc or not http://youtu.be/ZKkumjSgLK8 Quote Link to comment
digitalcarbon Posted October 4, 2013 Author Share Posted October 4, 2013 ifcMe - 7.1 - Example of me missing some ifc labeling seem like groups are a bad thing in ifc labeling http://youtu.be/RIpdGwKddls Quote Link to comment
digitalcarbon Posted October 4, 2013 Author Share Posted October 4, 2013 ifcME - 8.0 - referenced building did not show up in the correct location this referenced building did not show up in the correct location. even made a design layer view port of it in the source file and did a "offset" to the correct location then ref that "offset" layer only. http://youtu.be/U1F4qin2-wA Quote Link to comment
digitalcarbon Posted October 4, 2013 Author Share Posted October 4, 2013 ifcMe - 7.2 - Select ifc tool found http://youtu.be/sxdeME6aVu4 Quote Link to comment
Vectorworks, Inc Employee Luis M Ruiz Posted October 4, 2013 Vectorworks, Inc Employee Share Posted October 4, 2013 You are welcome Digitalmechanics. Quote Link to comment
