simbob Posted September 5, 2013 Share Posted September 5, 2013 REF: Vectorworks 2013 SP4 (build 190383). I am currently working on 4 plans consecutively, almost every time i switch between any VW quits, Initially i thought is was when copying objects, but not the case. I can open two files, do nothing, keep switching and within probably 2-3 switches VW will quit. This is happening on all 3 VW machines in our office, 1 iMac and 2 Mac Book Pro's. Been happening for a while, but only now when i've starting trying to homogenize these drawings for a tender package and am constantly flicking between them is it becoming a real issue and i'm starting to lose work and time. Seems stable enough when only working on one file even if others are open. Quote Link to comment
Kevin McAllister Posted September 5, 2013 Share Posted September 5, 2013 Open Activity Monitor and take a look at how much memory VW is using. Compare opening 1 vs opening 2 or 3 drawings. It may be as simple as a memory issue. When VW gets up around 2-2.5 GB it starts to fail pretty consistently for rendering viewports. This may be true of other operations as well. KM Quote Link to comment
Christiaan Posted September 5, 2013 Share Posted September 5, 2013 Try ditching your preference files: http://kbase.vectorworks.net/questions/1099/Resetting+Vectorworks+Preferences#OSX%20107-108 It's worked for us a few times recently. Quote Link to comment
simbob Posted September 6, 2013 Author Share Posted September 6, 2013 REF: Vectorworks 2013 SP4 (build 190383). I am currently working on 4 plans consecutively, almost every time i switch between any VW quits, Initially i thought is was when copying objects, but not the case. I can open two files, do nothing, keep switching and within probably 2-3 switches VW will quit. This is happening on all 3 VW machines in our office, 1 iMac and 2 Mac Book Pro's. Been happening for a while, but only now when i've starting trying to homogenize these drawings for a tender package and am constantly flicking between them is it becoming a real issue and i'm starting to lose work and time. Seems stable enough when only working on one file even if others are open. Thanks, but i only get 500mb for all 4 files! Quote Link to comment
simbob Posted September 6, 2013 Author Share Posted September 6, 2013 Try ditching your preference files: http://kbase.vectorworks.net/questions/1099/Resetting+Vectorworks+Preferences#OSX%20107-108 It's worked for us a few times recently. Thanks, i would try this if i could find the mythical 'Go' button it speaks of! Any pointers? Quote Link to comment
M5d Posted September 6, 2013 Share Posted September 6, 2013 Open a finder window first. That will change your drop down menus to the finder's. Quote Link to comment
simbob Posted September 6, 2013 Author Share Posted September 6, 2013 Try ditching your preference files: http://kbase.vectorworks.net/questions/1099/Resetting+Vectorworks+Preferences#OSX%20107-108 It's worked for us a few times recently. Thanks, i would try this if i could find the mythical 'Go' button it speaks of! Any pointers? Managed to switch hidden folders on with 'Terminal', deleted all prefs, working better but not solved. Still quits when switching docs especially if copying elements between. Quote Link to comment
Guest Wes Gardner Posted September 6, 2013 Share Posted September 6, 2013 Were you able to switch out the prefs folder? That will probably be Tech Supports first answer... Quote Link to comment
Christiaan Posted September 6, 2013 Share Posted September 6, 2013 Open a finder window first. That will change your drop down menus to the finder's. You need to hold the option key down when you click on Go. (no need to resort to the Terminal) Quote Link to comment
Kevin McAllister Posted September 6, 2013 Share Posted September 6, 2013 I saw a good tip online. If you need to access your Library folder a lot you can just add it to the Finder side bar. Then it's always available. KM Quote Link to comment
Vectorworks, Inc Employee PVA - Admin Posted September 12, 2013 Vectorworks, Inc Employee Share Posted September 12, 2013 (edited) It will seem like an odd question, but how exactly are you switching between open documents? Keyboard shortcuts, rearranging windows and simply clicking between them, or via the Window menu? Does the crashing occur regardless of which method you use? Edited September 12, 2013 by JimW Quote Link to comment
