blurry images in worksheet
yardstick
There used to be an option to alter the resolution, I believe as stated above it was dropped due to severe performance problems.
Most likely this will come back in the future, but for the moment you MAY be able to alter this quality by altering the DPI settings at the bottom of the File > Document Settings > Document Preferences > Resolution tab.
The default is 72, I recommend trying 150 or 300, then trying a print or export to PDF to check the quality against the default setting of 72. However if this DPI setting does not affect it, there may be no way to until they implement a direct one.
